Allora ho pensato di togliermi qualche curiosità ed ho inviato una mail al customer service........... spero di avere una celere risposta.
Per chi mastica o ingoia......(pervertiti)
Hallo, my name is ------------------ and i mailing from Italy.
I am very interested in the Jackpot Dyno Tuned 2/1/2 headpipes designed
specifically for the performance and tuning characteristics of the 96"engines.
I have a Road King Classic 2010 (FLHRC).
1- As i read that the Jackpot Dyno Tuned 2/1/2 headpipe has an Dual Stainless
Steel 18mm and 12mm Oxygen Sensor bungs that accommodate stock O2 sensors as
well as Wideband O2 sensors, giving users a wide range of options for EFI
tuners, i'll need to know if you also send both 12mm and 18mm bung plugs so
that i can choose which to install or installing them both.
2- I also read about your 2010 Harley Touring models Dyno Chart, more exactly
the dyno chart for the 2010 Electra Glide that shows the gains from the Jackpot
2/1/2 head pipe directly compared to the stock head pipe. Now what i would
like to know and if you can give me an answer is if i can obtain a similar
result on my bike equipped with Jackpot Dyno tuned mufflers, Stage 1 air
cleaner, and Dynojet PC-V?
3- Buying the Jackpot Dyno Tuned 2/1/2 headpipes can you send me a copy of the
map file used on Dynojet PC-V during your test?
4- Do you ship in italy, and if yes, can you let me know how much does it
costs.
5- And at last, as i saw that your ratail price is $449.00, and as they arrive
in Itay, i have to pay the 20%VAT on that price, plus customs duty, if you
have added your national VAT, can you subtract the charge or ----------- on
the payment invoice?
My address:
(BN)
ITALIA
Phone Number: 0039331-----------
Thank you very much an sorry for any misunderstanding!
Best wishes.
