Io l'ho preso in USA, su ebay Italia c'è un'inserzione in corso a 218,94 + 9,90 di spedizione; tutto sommato un prezzo onesto.vins ha scritto:...e quanto costa questo cioccolatino??
twin scan II da Twin Tec
Re: twin scan II da Twin Tec
Ora in vendita a 100€ per il forum compresa spedizione, accetto paypal
Di seguito le caratteristiche:
Twin Scan II ABS Low Cost Scan Tool
· Compatible with 2001-2014 H-D® fuel injected models using Delphi® system (including V-Rod®) with J1850 data bus and 2003-2006 carbureted models with new 12 pin ignition module. Note: Not compatible with 2011 later models with CAN data bus
· Anti-skid brake system (ABS) brake bleeding functions for 2008-2013 touring models. For more information, refer to the Twin Scan II Tech FAQ
· Support for new 2006 and later closed loop fuel injection systems
· Displays throttle position and twist grip sensor data on new 2008-2013 touring models with electronic throttle control
· Uses laptop PC for display. Includes Windows software
· Reads and clears diagnostic trouble codes from engine control module (ECM), turn signal/security module (TSM/TSSM), speedometer, tach, and anti-skid braking system (ABS).
· Real time display of engine data on instrument panel type display
· Built-in data logging. Stores up to 45 minutes of data. Automatically triggers when a trouble code is set. Shows data before and after code is set
· Includes two analog inputs for air/fuel ratio (AFR). All Twin Scan II ABS units can be upgraded to a Twin Scan II ABS Plus for use as tuning aid
· Compact size: 3.1"L x 1.6"W x 0.8"H
